IP blokeeritud, ei saa postitada
kaupz
PostitusPostitas kaupz » 09 Okt 2020, 21:22
millega ma selle ära teenisin Volvo foorumis ja kasutan Elisa 4g
4g rõõmud, tegin 4g-ruuteri restardi ja sain uue ip.
Sinu IP 146.255.180.11 on blokeeritud, sest see on mustas nimekirjas. Detailide jaoks vaata: http://www.spamhaus.org/query/bl?ip=146.255.180.11
146.255.180.11 is not listed in the SBL
146.255.180.11 is listed in the CSS
146.255.180.11
146.255.180.11 is not listed in the PBL
146.255.180.11 is listed in the XBL, because it appears in:
CBL Lookup
This lookup tool is for manual (non-automated) lookups only. Any perceived use of automated tools to access this web lookup system will result in firewalling or other countermeasures.
Not Listed. If the IP address or domain you are checking does not show as listed in the results above, then it is not currently in any Spamhaus blocklist. If you are getting email reject messages which say it is listed by a Spamhaus blocklist, then see this FAQ for a possible solution.
Listed. If the IP address or domain you are checking is listed in any of our blocklists above, this page will tell you which one(s) and will give you a link to the exact record. Follow the link. The linked page will explain why the address is listed and what to do to have it removed.
Re: IP blokeeritud, ei saa postitada
PostitusPostitas Klamber » 10 Okt 2020, 13:31
Mul oli sama asi paar nädalat tagasi, sai vist korda. Või siis ma kasutan teist arvutit ja ühendust.
