SEMA: Volvo XC70 Surf Rescue
Meedia volvodest, huvitavad lingid.
Moderaatorid: JaanKaer, Igor, Leho, bronec
pesa
PostitusPostitas pesa » 05 Nov 2007, 11:55
Ei ole just pädev tõlkija, postitan katkeid ingliskeelsest pressiteatest:
Guided by the surfing lifestyle and casual beach culture, the XC70 SR's brilliant yellow and red paint scheme is authenticated by Catalina Island's City of Avalon official seal. The Volvo XC70 is capable of back-country emergency duty; all-terrain victim support services and a broad array of rescue missions that are critical to those in need.
The Volvo Catalina Island Rescue unit epitomizes the company's slogan and offers rescue operations specialists a glimpse of what is possible - a safe, comfortable and capable response support vehicle from a manufacturer committed to the idea that human life is to be celebrated and preserved.
Wrapped with eye-catching Surf Rescue graphics and City of Avalon insignia, the concept model can be easily seen on a crowded beach, in deep canyon terrain or from air support equipment. It sports a custom-crafted front fascia that wears a one-off milled aluminum billet grille. Front and rear skid plates and wider wheel lip cladding has been added for extra body protection from flying sand. The new fascias also reduce front and rear overhang, thereby improving approach and departure angles.
The chassis has been lifted an additional five inches from the stock ride height for improved ground clearance. It also makes way for a massive set of custom designed 20-inch wheels and Pirelli 275/45R20 tires sporting a unique tread pattern for increased traction. The rear subframe has been beefed-up for added ruggedness with milled aluminum billet components.
True to form, the XC70 SR is topped by a unique aerodynamically designed roof-mounted emergency light bar integrated with a rescue board rack. Not only does this treatment contribute to the stunning good looks of the vehicle, it also helps to reduce wind drag by attaching directly to the XC70's OEM supplied roof rails.
he XC70's 3.2-liter in-line 6-cylinder normally aspirated engine produces 235 horsepower and 236 lb.-ft. of torque. It's mated to a six-speed "Geartronic" automatic transmission that enables the driver to shift manually when desired. All-wheel-drive with Instant TractionTM is standard. Electronic Hill Descent Control (HDC) uses the vehicle's brakes and engine torque to crawl in bottom gear on steep downhill slopes.
pildid autoblog.com
Esimene - V40 2001 2.0T 121kW
Teine - V70 2008 2.4 D5 136kW
taavi
PostitusPostitas taavi » 05 Nov 2007, 12:18
natuke OT, aga venelased aitavad uppunud surfareid nii: http://tazavi.planet.ee/kola/niva.pps (powerpoint'i fail, 3.2MB suur)
PostitusPostitas Volvo75 » 05 Nov 2007, 14:17
Kas tõesti see Niva sõitis ise välja....vägev värk...naljakas on see "uue niva" esinduspilt....miski pole sümmeetriline :D
mairold
PostitusPostitas mairold » 05 Nov 2007, 14:25
taavi kirjutas:natuke OT, aga venelased aitavad uppunud surfareid nii: http://tazavi.planet.ee/kola/niva.pps (powerpoint'i fail, 3.2MB suur)
autopesu :)
VOLVO 740 - vana armastus!
Re: SEMA: Volvo XC70 Surf Rescue
PostitusPostitas vanapeer » 05 Nov 2007, 15:12
pesa kirjutas:Ei ole just pädev tõlkija, postitan katkeid ingliskeelsest pressiteatest:
Guided by the surfing lifestyle and casual beach culture, the XC70 SR's brilliant yellow and red paint scheme is authenticated by Catalina Island's City of Avalon official seal.................
pildid autoblog.com
kuram nagu see surfing ise juba s**aks raha ei võtaks
