Race.Fi: news & introduction
Performance & Tuning parts for Volvo!
Siia postitage oma "Performance & Tuning" uue ja kasutatud kraami Müügikuulutused!!
Race.Fi
Re: Race.Fi: news & introduction
PostitusPostitas Race.Fi » 14 Juul 2017, 14:53
Weekie on Brisk and NGK -10 %
Even the latest summer cars should now be on the road, and in case testing reveals sputtering, here's some medicine to cure problems at least as far as plugs are concerned.
On the traditional weekie are Brisk and NGS plugs. All plugs are also plentiful in our own stock. The product descriptions offer more details than this topic including a cross reference chart of heat ratings.
NGK plugs are often told to be the one and only working plug especially in some turbocharged jap models. Why not, they're good plugs =)
From Brisk there are several models which are listed in the shop:
DS / Turbo -models: Especially for E85 and high boost pressure builds where no other plugs simply work.
LGS quad tip models: For cars with direct ignition plugs. Produces a good and long spark so these are also the most economical version.
Iridium -models: A traditional Iridium plug which can handle high temperatures are pressures. Easier on the coils and also suitable for mild E85 builds.
Silver: Competition engines and for hard to ignite fuels.
VAG -models have their own plug range.
»» Brisk Iridium plugs
»» Brisk LGS quad tip plugs
»» Brisk Silver plugs
»» Brisk DS plugs
»» Brisk VAG plugs
»» NGK Iridium plugs 6 - 9 heat range
Have a great weekend! Race.Fi / Wille
This topic on our website
Race.Fi
PostitusPostitas Race.Fi » 25 Aug 2017, 14:27
Weekie: Luisi steering wheels and hubs -10 %
Luisi's steering wheels and bolt-on hubs have earned their permanent place in our range.
Luisi has made steering wheels and hubs since 1965. There's a hub and wheel for every car!
You can find the basic model hubs in the webshop, and can get the airbag models (not street legal) from sales as they are much less sold. There's suede and pu wheels, and hundreds of bolt-on hubs at great prices, so check them out in the shop.
Steering wheel hubs have a double pcd which includes most common steering wheel brands (6x70 & 6x74mm).
For example: FK, JOM, Tuning Line, Sparco, Momo, OMP and naturally Luisi steering wheels will bolt straight on.
Check out the Luisi range from our webshop:
»» Luisi steering wheel hubs
»» Luisi steering wheels
Other things from this week
Brisk & NGK spark plugs for every purpose!
»» Brisk and NGK sparkplugs
D2 coilovers: value for money. The best coilover kit in the price range for every car.
»» D2 coilovers: Value for money
Cometic gaskets and arp bolts are the choice when building any engine.
»» Cometic & ARP
High quality turbosmart boost controllers and blow off valves work accurately in all circumstances.
»» Turbosmart bleeds and BOV
-Riku
Race.Fi
PostitusPostitas Race.Fi » 08 Sept 2017, 14:29
Weekly offer: OBP -10%
The UK-based OBP's handbrakes and pedalboxes offer optimum balance - and optimum braking. They are now celebrating their 10-year anniversary, so lets celebrate that with a -10 % off all OBP products.
OBP Hydraulic handbrakes
OBP handbrakes come in several flavors in either vertical, horizontal or an angled setup, with 280 or 600 mm handled, and for a twin or single line. Cyliners are standard size and exchangeable with most handbrake/pedalbox cylinders. This means the OBP cylinders we sell separately also fit most other handbrake and pedalbox brands.
Check out the handbrakes here.
»» Race.fi: OBP hydraulic handbrakes
OBP Pedalboxes
OBP pedalboxes are available as bolt-on (well, as bolt-on as a pedalbox can be), or universal setups for either floor- or firewall mounts. All kits can be ordered with or without cylinders, for different clutch setups and the optional bias quick adjustment which basically lets you turn the bias bar on the fly based on driving conditions. A pedalbox is the best solution as far as competition brakes go; they offer adjustability, direct feel to the brakes and remove dependency to engine vacuum.
»» Race.fi: OBP Pedalboxes
The most common handbrakes and pedalboxes are found directly from our stock, like most of our brake cylinders and line locks.
OBP supplies:
»» Race.fi: OBP line locks
»» Race.fi: OBP bias valves
»» Race.fi: OBP brake cylinders
Other news this week
Amsoil makes a high performance oils and additives!
»» Amsoil oils and additives
Eibach manufactures wide range of lowering springs, suspension kits and wheel spacers!
»» Suspension in shape with Eibach
K&N air filters will allow better fuel economy and more pure power!
»» K&N air filters
Quaife differential is one of the best updates for your car!
»» Quaife differentials
Have a nice weekend!
-Riku
Race.Fi
PostitusPostitas Race.Fi » 29 Sept 2017, 14:30
Weekie: Quaife differentials -5 %
Quaifes are no new thing, but inarguably among the best diffs you can get!
Diff sales are starting to climb, as thanks to our "summer", winter memories are still very clear :D We're now living some kind of strange mini-summer over here in Finland, so lets put the Quaifes on a -5 % sale.
If you're familiar with Quaife, then just go get your's while they're on offer. If not, here's why you should get one:
» Works with the original traction control.
» Lifetime warranty including motorsports.
» When you want, you can drive like a gentleman wihtout noise, or push the car to the limits - it's your choice.
» No additional noise or vibrations.
» Never completely locks the wheels, but instead transfers more power to the wheel that has more traction.
» Manufactured and designed in the UK.
» A good choice for slippery conditions unlike clutch-type diffs which completely lock the wheels.
» In the opinion of many of our customers: The best modification they did on their cartop.
The offer is valid until next friday, and the units are of course discounted in the shop directly. The discount is not huge, but on the other hand our starting prices aren't huge either so this is a good deal ;)
»» Quaife ATB differentials
A new Cloud9 server
Like cars, servers also need some upgrades from time to time. Something like putting a bigger Garrett in there.
Our site moved to a new Finnish Nebula Cloud9 hosting platform. As most readers are car junkies, lets skip the intel-ssd-ht-128gb-http2 stuff.
What the transfer means is:
» More power for the ~double amount of visitors compared to last year.
» That way, lower latencies and a generous reserve for the future.
» Needless to say; state of the art security protocols so you can leave off the folio cap when browsing, on our site at least :D
Our Service Manuals -section
What's a service manual? Well it's a manual usually published by the car factory which is used by professionals when they work on a car. The manual answers questions from the correct plugs to the main cap torque rating and -order.
We dont have a manual for each an every car, but managed to upload quite a nice selection of the models usually surfacing in FB/forum discussions. We'll keep updating these, and are also open for suggestions in case you have a manual that needs hosting - after all, we've got that shiny new server just drooling for more traffic ;)
»» Race.Fi: Factory service manuals
Have a good weekend! - Willem
Race.Fi
PostitusPostitas Race.Fi » 20 Okt 2017, 11:00
Weekie: Cusco limited slip differentials -5 %
Quality for a slightly smaller price, namely the Japanese Cusco limited slip differentials. If you know what Cusco is, then it might be time to do some shopping, and if not, then definitely give this post a read.
Cusco develops, others copy. So it goes, and there's nothing wrong with it. This Japanese elite racing brand tests and develops all their products with the Japanese top quality mentality, and the result is a brand which is seriously respected.
This weeks offer is for the Cusco Type-RS and -MS limited slip differentials, which are plate type differentials. They are completely serviceable and offer tons of grip as well as predictable and linear driveability. All Cusco differentials are completely serviceable. Havin represented Cusco in Finland for over 10 years, we carry all service kits and also offer each and every part of the differential as spares as well.
Cusco offers two main types of differential, and both are on sale.
Type-RS is a street version where the RS springs push the differential open. It means this differential is as streetable as a plate-type diff comes. When more torque is applied, this grips like a beast.
Type-MZ is a pure track differential, where the MZ springs preload the clutch assy to give a very linear and strong grip even in those very high powered cars where regular differentials fry.
Cusco differentials, on sale, are found here:
»» Cusco Type-RS and -MZ limited slip differentials
If you want to refresh your memory on what the different types of differentials are, and what each term like 1-way or 2-way stand for, take a read here:
»» Limited slip differential 101
For all the differential brands we carry, check here:
»» Race: limited slip differentials
Have a great and grippy weekend!
Race.Fi / Willem
Race.Fi
PostitusPostitas Race.Fi » 27 Okt 2017, 15:12
Weekly: Wideband gauges on offer
On weekly offer: PLX, Vems and Innovate 4.9 sensor wideband kits.
On offer for the next week are some nice little packages to get the winter season in the garage started. Snow just fell over here in Finland, so we're all just crawling back to the welcoming warmth of our garages.
Vems widebands
Wideband available with EGT or without. One of our models thats been on sale for a long time Vems wideband with 4.9 sensor. Includes 52mm gauge which monitors exhaust temperatures on celsius or farenheit. Fuel mixture in ratio or lambda value.
Operating unit is in the gauge, so there is no external box to take space.
Pilt Pilt
Innovate widebands
Innovate has to models which we sell, DLG-1 which is excellent for V-engines. It includes two lambda sensors. MTX-L and DLG-1 widebands both come with 52mm gauge and 4.9 sensor.
Operating unit is in the gauge, so there will be no external box to take space.
PLX widebands
Top seller, and most inquired wideband. Plenty of choises to chain information such as manifold pressure (sold separately). Includes 52mm gauge with touch screen.
This model has operating unit separately in box, which can be chained with plenty of options for example EGT, manifold pressure and more.
Check out the widebands in our webshop:
»» Race: Vems widebands
»» Race: PLX widebands
»» Race: Innovate MTX-L widebands
»» Race: Innovate DLG-1 widebands
»» Race: PLX modules
»» Race: Bosch wideband sensors
Race.Fi
PostitusPostitas Race.Fi » 03 Nov 2017, 15:13
RVS treatments on -10 % for one week
RVS treatments are on promo for the next week with a -10 % discount. All products in stock as well!
RVS treatments are a proven way to restore some older engines and transmissions to their original compression specs and tolerances. We just got a huge shipment of RVS, so it's time for some promotions =) If you're not familiar with these, ask your friend who is or check out our website for some more info!
Without longer talks, here you go:
»» RVS treatments
Have a great weekend Race.Fi / Willem
Race.Fi
PostitusPostitas Race.Fi » 10 Nov 2017, 15:14
Weekie: Gripper differentials -10 %
Gripper differentials offer top notch competition differentials with tailored ramp angles and preloads. Now on weekly offer for -10 %!
Gripper is a quality differential made in Convetry, Great Britain. Gripper differentials are always shipped with your choice of ramp angles and a customizable preload. The differentials are also fully rebuildable and serviceable. Naturally, you can get all the service kits from us as well.
Check out and order you Gripper diff here:
»» Gripper differentials
Professional motorsport: here we come!
Next week Willem will visit the Professional Motorsport show in Cologne, Germany. The exhibition gathers all the top notch brands and suppliers literally under one roof, and is a great chance to say hello to our exiting partners face to face, as well as do some scouting on new opportunities and trends. Expect a follow up an a full debreef shortly =)
Fiddling through the different types of limited slip differentials can be a tiresome task and there are a lot of terms which are pretty vaguely used on the internet. We did a differential 101 writeup while ago, and it is very on topic now that the season has started.
»» Differentials: a tough choice?
Black Diamond all-round kits -10 % from our sales!
»» Black Diamond: Full sets -10 %
Holset turbocharger prices were just updated, and to your joy, they were lowered. Most models are also available in stock or in a few days.
»» Holset prices updated
Have a great weekend! Race.Fi / Willem
Race.Fi
PostitusPostitas Race.Fi » 17 Nov 2017, 11:34
Weekie: Mishimoto -10 %
On our weekly offer, the Mishimoto intercoolers and radiators. Time to get an upgrade?
On the weekly for the following week are Mishimoto radiators and intercoolers. Aluminium radiators are available for many car models as bolt-on upgrades, and made by Mishimoto they are both of great quality and very decently prices. Mishi is a great brand falling behind the big brands in price, and still offering great products with great value for money.
Get your's while these are on promo. Shipping from 9,90 € abroad, and free for orders over 400€.
»» Mishimoto radiators, intercoolers, hose kits etc.
Sore feet
Willem chimed in and it's been a great trip to Cologne, Professional motor show. There are tons of new products and ideas to talk about, and we'll hear some more about them next week!
Walbro, simply the market leader for fuel pumps with good reason. And of course, in stock with a fresh shipment of GSS341 and GSS342 pumps.
»» Walbro fuel pumps: always in stock
Sleeves, wraps, stick-on deflectors and other heat management stuff - you name it, Thermotec has it! We stock it!
»» Thermotec: Protects, insulates, finishes
Have a nice weekend! Race.Fi / Ari
Race.Fi
PostitusPostitas Race.Fi » 21 Nov 2017, 15:14
First Black Friday offer: Wisefab kits -10 %
The first black Friday offer has all Wisefab kits at whopping 10 % discount. These are very rare on discount, so now's your chance to get your kit at a great price!
All regular Wisefab kits are available below. We carry all Wisefab kits and ship the free of charge, so if your model is not on the website, ask our sales and we will supply all the most recent models as well.
»» Wisefab lock kits
Race.Fi
PostitusPostitas Race.Fi » 24 Nov 2017, 12:03
Black Friday megasale til 6pm!
All Black Friday offers combined, as well as our new weekly offer: Sachs SRE products -10 %!
The Sachs SRE range offers great clutches at great prices. There's a kit for almost every car, and now on a very good price as well. On the site, you'll find all products by their code, and a PDF with an application list. In case you don't feel like going through the lists, just tell our sales what car you've got and we'll make you an offer which is hard to turn down!
»» Sachs SRE clutches
Sachs SRE 763, 765, 707, 645 and 785 covers
Here they are, the five most sought-after performance clutch covers. These babies offer great clamping force and found on many aftermarket performance kits.
»» Sachs SRE 763, 765, 707, 645 and 785 covers
Oh, and those Black Friday offers =)
Black Friday: RVS treatments -10 %
All RVS products -10 %, all usual products in stock as well =)
RVS. Restores and protects. This stuff is very praised and gets tons of great feedback. We've seen many return customers for RVS, and that is one of the strongest signs for a good product.
»» RVS treatments
Black Friday: Powerflex bushes -20 %
Powerflex: the number one brand for suspension bushes now on bf sale -20 %
All bushes with reduced prices. All bushes can be filtered by make, model and variant for easy selection.
»» Powerflex bushes
Black Friday: Black Diamond products -10 %
Discs, pads and hoses. All you need to get proper brakes on your car. Now on a -10 % black friday sale!
Proper brakes, now for a bargain:
»» Black Diamond brake discs
»» Black Diamond brake pads
»» Black Diamond brake hoses
Black Friday: Thermotec 30x30 heat sticker -20 %
A darn nice sticker for heat protection. This comes in a small enough package so you don't need get a square meter of this stuff, and protects hoses, pipes, and whatever someone decided to put too close to that exhaust manifold.
A handy sticker, and we've still got enough in stock to cover a middle-sized sedan with this suff. Get your's while stocks last though ;)
»» Thermotec heat shields
Black Friday: Eibach springs & B12 kits -20 %
German-made quality suspension: the Eibach Pro-Kit and Sportline springs as well as the B12 series suspension kits -20 %
Eibach Pro-Kit springs offer drops from 30 to 35mm, and the Sportline kits all the way up to 50mm. Eibach's B12 kits come with Bilstein B8 shocks and offer a very competitive kit at a great price. Now on Black Friday offer at -20 %. Get your's here:
»» Eibach Pro-Kit springs
»» Eibach Sportline springs
»» Eibach B12 Pro-Kit suspension kits
»» Eibach B12 Sportline suspension kits
Black Friday: K&N cone filters -20 %
On Black Friday offer, K&N 3- and 4" cone filters. Naturally they're all in stock as well!
A K&N cone filter is a properly flowing and durable air filter which is both washable & reusable and very durable in even harsh conditions.
We stock four different models in 3- and 4-inch sizes, short and long versions, so you'll find a suitable filter for any engine bay.
»» K&N cone filters
Black Friday: Magnaflow catalyzers -20 %
Second of many Black Friday offers: All stock Magnaflow catalyzers -20 %!
Magnaflow catalyzers receive constant praises, and with good reason: in addition to free flow and power gains in especially turbo cars, these little pussies also perform way better on emission tests than original, clogged cats.
At the time of writing, all cats are in stock, so get yours while stocks last, and at least before friday afternoon when the BF-offer ends.
»» Magnaflow catalyzers
As always, have a great weekend! Race.fi / Ari, Willem and Jaana!
Race.Fi
PostitusPostitas Race.Fi » 01 Dets 2017, 14:55
Monthly: Amsoil -10 to -40 %
Decembers starters are the Amoil oils at a generous monthly offer. These oils get tons of great feedback, and now's the time to make room for new stocks!
Lets start with a small story (translated from Finnish): I was visiting Professional Motorsport a while ago, and tend to check company emails and facebook messages even though we do have staff at the warehouse. It's an entrepreneurs habit. There I sat, eating breakfast (=drinking coffee), and the phone let me know there was a new message. It started with a controversial "F**ck guys!". As you know, phones don't show the complete message, only the first few words on the notification bar.
I almost inhaled the coffee and thought "well, this day started great....".
I opened the message, and it continued: "Now the s**t *** oils (brand-service suggested oil), are out, and Amsoil put in place. I have sometimes used *** -oil, but it didn't work in cold conditions. I hope Amsoil works in the cold mornings as well, but i wouldn't have believed a transmission which is usually regarded an "all of these are hard to shift" -transmission, could shift this easily! gears can be hanged with one finger!
Anyways. I rarely feel like giving great feedback, but this feels great! Especially if it still works tomorrow morning!
". And guess what: it did.
- Willem
A permission to use the feedback was asked and the less-performing oil names are removed as that is simply polite.
Needless to say, that kind if feedback makes our day, and is the best indicator of product which is genuinely good! Measurements, lab tests and great-looking banners are far far behind from a clear feedback like this.
Amsoil products are on offer directly in the webshop:
»» Amsoil oils
Everyone knows Quaife belongs to the differential royalty, but it still doesn't mean you should use blue oil as in blue-blooded royalty. Here are a few questions which are commonly asked.
»» A few common Quaife questions
D2 coilover sales have skyrocketed thanks to the new inspection regulations, where traditional TUV approvals can be replaced with other documents as well. We will now inlcude an inspection document for all coilover kits.
»» D2 coilovers shipped with road-approval
Turbosmart wastegates and manual boost controllers just got some pretty decent price updates. Check these out!
»» Turbosmart: price updates
Stocks were just replenished for Race.Fi products. Dump valves, fuel pressure regulators, oil coolers, oil cooler install kits, engine mounts. You name it, we stock it.
»» Lots of new Race.Fi product stocks
Race.Fi
PostitusPostitas Race.Fi » 08 Dets 2017, 13:55
Weekly offer: D2 air suspensions
On weekly offer is the low'n'comfy way of driving. All D2 air suspension kits are on sale until December 15th. These kits are as bolt-on as an air suspension comes!
Available in four different flavors, the D2 air suspension kits come as bolt-on as air suspensions can. The ready assembled struts will bolt right on, and a compact compressor + tank assembly goes in the trunk.
The Basic kit allows a road-scraping height on the show field, and easily lifts to a usable height when you drive your car. Deluxe, Gold and SuperPro offer more features like independent solenoids for each wheel, memory slots for height and automatic leveling.
Get your kit here:
»» D2 air suspensions
While you're at it, also do check out the D2 big brake kits. If you're after a simple coilover kit, check out the coilovers:
»» D2 alustasarjat
»» D2 etujarrusarjat
»» D2 takajarrusarjat
All orders over 400€ are shipped free of charge to most EU countries ;)
Race.Fi / Willem
Race.Fi
PostitusPostitas Race.Fi » 15 Dets 2017, 14:58
Weekly: Luisi steering wheels & hubs -10 %
Easing the joy of winter "drifting": Luisi steering wheels and hubs. Over 700 model specific hubs and several suede and PU steering wheels.
Luisi has made steering wheels and hubs since 1965. There's a hub and wheel for every car! Check out the Luisi range from our webshop:
Monthly offer: Amsoil oils
»» Amsoil oils on offer
Independence day promise
We're doing pretty well in Finland. Our lives always have ups and downs. Thanks to our veterans who fought, and from whom some paid the ultimate price, those ups and downs are relatively mild. To thank these men and women, we will donate 1% or a minimum of 500 € for veteran care from our December sale.
»» Happy independence Finland
Race.Fi / Willem
Race.Fi
PostitusPostitas Race.Fi » 22 Dets 2017, 15:21
Merry christmas everyone!
Merry christmas 2017! Soon we'll pack up and are done with this week, but before the long holidays, here's the weekly: Powerflex bushes -10 %
Powerflex bushes could be put on a Christmas tree with their bright colors, but seriously, they're the way to go when updating either one or all suspension bushes. As said, Powerflex is on our weekly offer starting now, to 29.12.2017.
You'll find the bushes easily from the web shop by checking with brand, model or bush stiffness. Powerflex bushes -10%
»» Powerflex bushes
Magnaflow catalyst are very powerful cleaners despite the small size. Magnaflow will also pass an emission test easily and of course still offer great flow. There have been lots of questions about catalyst dimensions, so we decided to measure each one of them and list them on the site as well. Metallic catalysts are only 203 mm long, so even a regular 0.5l water bottle is longer
»» Race.fi: Magnaflow catalyst
We checked the whole Amsoil products catalog, and now there are over 140 high-res pictures from the oils and additives.
»» Race.fi: Amsoil products
We just got a huge amount of Holsets and turbo hardware in our stock. You can find almost everything in our stock or with day or two delivery time.
»» Race.fi: Turbo products
Merry Christmas
Riku just got his military service finished, and we are now working with the full team again. Our team above, Riku, Jaana, Willem and Ari wishes great Christmas to all!
Have a great holiday weekend! Race.fi / Ari, Willem, Jaana & Riku
