hind 20 euri
Features:
The power inverter is ultra compact and portable and represents the new trend of high frequency converters. Whether it is connected with the cars or other 12V power supply, it can provide safe and reliable AC voltage for electrical appliances such as TV, DVD machines, etc. It comes with a variety of protection functions, protecting your converter, battery and electrical appliances effectively in overload state.
Convert DC 12V electricity source into AC 220V / USB 5V power
Compact and portable design.
Work without noise.
Widely used for all kinds of electric equipments such as TV, DVD, portable computer, etc.
On / Off switch control the fan
Automatic thermal shutdown
Overload protection
Extra surge capacity
Low battery alarm & shutdown
Reverse polarity protection
Specifications:
Power: 200W
Output Voltage: AC 220V, 50 +/- 2Hz
Output Waveform: Modified sine wave
Input Voltage Range: DC 12V
Fuse: 10A / 15A / 20A / 40A / 70A
Low Battery Alarm(Nominal): 10.4 ~ 11.0V
Low Battery Shutdown Point(Nominal): 9.7 ~ 10.3V
High Battery Shutdown Point(Nominal): 14.5 ~ 15.5V
No-load Current(At 12V input): < 0.3A
Peak Efficiency: > 90%
Continuous AC Output Power: 50W / 80W / 120W / 240W / 400W
30-minute AC Output Power: 60W / 100W / 150W / 200W / 200W
Maximum AC Output Power: 120W / 200W / 200W / 400W/ 1000W
Operating Temperature: 0 ~ 40℃
Net Weight: 250g
Product Size: 87mm x 63mm x 37mm
Caution: Do not expose to water drip or spray; make sure the machine is well ventilated.
Package include:
1 x Power Inverter Adapter
1 x Conversion Plug ( US Plug)
asub Tallinnas
ühendust saab PS teel tel 56791733
