M: Inverter voolumuundur 1000W
Siin võib müüa ja osta ka muud kraami (Volvodega mitteseonduvat).
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
marx001
PostitusPostitas marx001 » 24 Mai 2017, 14:57
Uus inverter voolumuundur 1000W
hind 45 euri
1000W Power Inverter DC 12V AC 220V Car Converter Electronic USB Port
Features:
● High converting efficiency.
● Under voltage shutdown protection.
● Overload protection, overheat protection.
● Invert DC 12V to household AC 220V, power a wide variety of household AC products.
● Provide 1000W of AC power and 2000W surge power.
● Low battery alarm, low / high battery shut down.
● Automatic thermal shut down.
● Safely shuts down if under over temperature or overload condition.
● Operate a 25 inch TV for about 4 hours from a typical car battery.
● Advanced chip technology, high conversion efficiency.
● Intelligent cooling fan system, CPU microprocessor to realize multiple protection.
● Protect the electrical and automotive circuits in use.
● Can be operated with your car cigarette socket or direct connected with wires clips.
● Adapting Aluminum Alloy case, antioxidant, sturdy and durable.
Technical Parameters:
● Input voltage: 10 - 15V (DC 12V)
● Output voltage: AC 220V
● Output frequency: 50HZ plus / minus 5 percent
● Output waveform: Modified sine wave
● Fuse: 10A / 15A / 20A / 40A / 70A
● Over heat protection: 60 deg.c plus / minus 5 percent / 60 deg.c plus / minus 10 percent
● Low Battery Alarm (nominal): 9.5 - 11.0V
● Low Battery Shutdown Point (nominal): 9.0 - 10.5V
● High Battery Shutdown Point (nominal): 14.5 - 15.5V
● Unload current: Less than 0.3A
● Conversion efficiency: More than 80 percent / More than and equal to 93 percent
● Continues AC Output Power: 550W
● 30-minute AC Output Power: 500W
● Maximum AC Output Power: 1100W
Note:
Actual power: 500 - 700W
Color: Silver
Package weight: 0.843 kg
Product size (L x W x H): 17.00 x 9.00 x 5.00 cm / 6.69 x 3.54 x 1.97 inches
Package size (L x W x H): 24.00 x 24.00 x 7.50 cm / 9.45 x 9.45 x 2.95 inches
Package Contents: 1 x DC to AC 1000W Car Power Inverter, 2 x Crimper, 1 x Car Charger Adapter, 1 x Bilingual User Manual in English and Chinese
asub Tallinnas
ühendust saab PS teel tel 56791733
