M: Autodiagnostika elm327
Siin võib müüa ja osta ka muud kraami (Volvodega mitteseonduvat).
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
marx001
PostitusPostitas marx001 » 24 Mai 2017, 14:41
Uus autodiagnostika ELM327
hind 10 euri
Features:
Button design
Read and erase diagnostic trouble codes (DTCs) and turn off the check engine light
Compatible with Systems: DOS, Windows
View real-time vehicle data, graphs and performance parameters while you're driving
Find and fix problems before they happen
Compatible with all OBDII compliant vehicles
Clear diagnostic trouble codes and turn off check engine lights
Display and record real-time sensor data, including:
Vehicle Speed
RPM
Fuel Consumption
Engine Coolant Temp
Fuel Pressure
Calculated Engine Load
Throttle Position
Intake Manifold Pressure
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
Fuel Trim
+ More
Note : Your vehicle may not support all engine metrics. The availability of engine metrics varies depending on the vehicle make and model
Compatible Protocols:
ISO15765-4 (CAN)
ISO14230-4 (KWP2000)
ISO9141-2
J1850VPW
J1850PWM
Specifications:
Model: B11
Output protocol: RS232
Baud rate: 9600 or 38400
LED indicator: OBDTx/Rx, RS232Tx, power supply
Working voltage: 12V
Working current: 45mA
Material: Plastic
Color: Black & white
Net Weight: 32g
Package included:
1 X ELM327 OBD2 Scanner
1 X CD software
asub Tallinnas
ühendust saab PS teel tel 56791733
