M: Automakk (Bluetooth, USB, SD, AUX)
Siin võib müüa ja osta ka muud kraami (Volvodega mitteseonduvat).
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
marx001
PostitusPostitas marx001 » 24 Mai 2017, 14:31
Uus automakk bluetoothi, USB, SD ja AUX-ga
Hind 30 euri
Car Radio 12V Bluetooth V2.0 Auto Audio Stereo MP3 Player
1068 Car Audio is equipped with FM radio presets for all of your favorite stations. If your road trip requires some of your own tunes, simply plug your iPod, iPad, or MP3 player into the front auxiliary input to play your favorite music instantly. For those that prefer an SD memory card or USB flash drive for storing music, just insert the device into the slot. Bluetooth audio streaming, making hands-free call.
Features:
- Built-in Bluetooth V2.0, microphone.
- Support hands-free calls function.
- Support advanced audio transmission mode.
- Clock indicating while power is off.
- High-definition digital stereo FM / AM radio.
- Support three-band radio store FM1 - FM2 - FM3, can preset 18 radio stations (Radio frequency: 87.5 - 108MHz).
- Support USB / SD card reader, up to 32G (not included).
- Support audio: MP3 / WMA / WAV / APE formats and so on.
- Support folder play function.
- Support break point memory and ID3 play.
- Remote control function.
- MP3 play supports pause / preview / repeat / random play and 10 tracks up / down selections.
- Electronic type bass / treble, left and right, front and back, channel separation, volume control.
- Multiple EQ scenario mode choice: Jazz, rock, pop, classic, etc.
- Support mute and equal loudness control.
- Front AUX audio input hole and rear terminal L / R audio RCA output hole.
- 4 track high-power output (4 high-power loudspeakers) 62W x 4.
Specifications:
FM Radio
Sensitivity: 22db
Medium frequency: 10MHz
Some Playback
Music format support: MP3 / WMA
Display format: ID3 display
Power Supply
12V Machine: 11 - 16V
Note: This machine is 12V machine, not according to the 24V power supply
Audio
Operating temperature: -20 - 60 deg.C
Quiescent current speaker impedance: 4 - 8ohm
Frequency Response: 20 - 20000Hz
Remote Control
- Build-in lithium cell: CR2025 3V
- Remote range: 5m
Type: Car MP3 Player
Model: 1068
Features: Controllable power switch,Breakpoint memory playing,One-click folder playing
Color: Black
Material: Electronic Components,Metal,Plastic
Installation Space: 1-DIN
Output Power: 4 x 62W
Voltage: 12V
Music Source: SD card,USB flash disk,3.5mm stereo headphone jack,Cellphone
Micro SD/TF Card Expansion (Max.): 32G (not included)
Built-in EQ: Pops,Classic,Jazz,Rock
SNR (dB): more than 60db
Bluetooth version: 2.0
Bluetooth protocol: A2DP
Transmit Distance: 10m
Media Format : WMA,MP3,WAV
Package weight: 0.681 kg
Product size (L x W x H): 18.800 x 12.000 x 5.800 cm / 7.402 x 4.724 x 2.283 inches
Package size (L x W x H): 21.500 x 18.500 x 8.000 cm / 8.465 x 7.283 x 3.150 inches
Package Contents:
1 x 1068 12V Detachable Front Panel Car Audio Stereo FM Bluetooth V2.0 USB SD Mp3 Player,
1 x Remote Control,
1 x Wire,
1 x English User Manual
asub Tallinnas
ühendust saab PS teel tel 56791733
