kas keegi oskab nõu anda,kuidas saaks ta raadiosagedused panna käima paarisarvudel,hetkel mängib vaid paarituid(usa variant)!
Ette tänades!
hu-650
Re: hu-650
Pakun, et usa variandil ei saagi, sest seal kasutusel paaritud sagedused ja seepärast seal müüdavatel masinatel tavaline.
- vanapeer
Re: hu-650
Oli küll mingi trikk... Kuskilt on läbi käinud...näiteks viewtopic.php?f=17&t=4269&hilit=sagedus*
Re: hu-650
kas keegi midagi täpsemat ei oska öelda,ise proovisin sellist varianti ( viewtopic.php?f=21&t=4007 ) ,kuid see ei õnnestunud!
Re: hu-650
I have HU-655 and it also has this hidden menu. So therefore I can claim that every HU has this menu and settings.
Try this per size, like I did: When key is in ACC position, and radio is off (press on/off switch to turn it off), then press and hold >>| button. Then push on/off switch to turn the radio on. Wait few seconds (about 7 or more) while you still hold the >>| button. They you should see some numbers and letters on display (version number) And then you just simply move yourself thru the menu, until you find country selection. But be careful not to mess other things up. My HU model doesn't have 1-20 knob either, but I can make all settings anyway. My model also has "menu" knob (for obvious radio settings like bass, treble...), and If I hold it and then turn the radio (as describen above), it jumps directly to the country-selection sub-menu.
if it doesn't work, try also with |<< and TP button
S60
Re: hu-650
proovisin eile ka ise seda ,kuid jällegi ebaõnnestus...pean vist täna veel proovima,äkki tegin midagi valesti!Kas teistel kellel see probleem on olnud on sellest abi olnud?
Re: hu-650
As far as the new generation of HU-xxx (HU-650, HU-850, etc.) head units is concerned, there are no more hidden menus.
Küsi IAs, mida teha. Ma kardan, et arvutiga ainlt saab vahetada ja ainlt IAs.
S60
Re: hu-650
jah,infos saab küll,tuleb uus tarkvara tõmmata!
Re: hu-650
Tule minu juurde Viimsis, proovin 200 kr korda teha.
Urmo,
52 25 724
Urmo,
52 25 724
