Side marker lamp replacement
Slide the lamp insert backward and pull out. Try to loosen the lamp insert with your fingers if possible.
Otherwise use a stiff piece of plastic or wood to protect the paint. Turn the bulb holder counterclockwise
and pull out. Replace with a new bulb. Press in the bulb holder and twist clockwise. Reinstall
the lamp insert by pressing it into the bodywork.
I põlvkonna mudelitel saab vahetada ainult tervet tuld.
