Uus auto tagurduskaamera
Hind 30 euri
Item Description:
Specifications of Monitor:
TFT-LCD Parameter:
- Voltage: DC 12V / 24V
- Size: 4.3 inch TFT LCD
- Resolution: 480 x 272
- Display Format: 16 : 9
- Operation Temperature: -20 ~ +75 degrees
- Storage Temperature: -30 ~ +75 degrees
- 2 AV for a camera for rear view and front view or side view
Signal System: PAIL / NTSC auto switchable
Current Consumption: 3W ( max )
Car Monitor Color: Black
Product Size(L x W x H): 130 x 80 x 26mm
Product Weight: 147g
Package Size(L x W x H): 145 x 100 x 65mm
Package Weight: 222g
Specifications of Camera:
TV System: PAL / NTSC
Effective Pixel: 628 * 586 / 828 * 686
Sync System: Internal
Scanning System: 2 : 1 Interlace
Resolution: 420 TV lines
Lens Angle: 18mm / 170 degrees
Sensor Area: 5.961mm x 4.276mm
Video Output: 1.0Vp-p, 75Ohm
S / N Ratio: More than 48 db
Water-proof: IP67 - IP68
Current Consumption: No more 300mA
Power Supply: DC 12V
Operating Temperature: -20 ~ 60 degrees(RH95%Max.)
Storage Temperature: -20 ~ 60 degrees(RH95%Max.)
Other Items: Automatic white balance, Agc and BLC
Package Weight: 131g
Package Dimensions(L x W x H): 135 x 84 x 65mm
Package Including:
1 x Monitor
1 x User Manual
1 x Power Cable
1 x Car Camera
1 x Manual
1 x Video Cable
1 x Power Cable
asub Tallinnas
ühendust saab PS teel tel 56791733
M: Tagurduskaamera
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
