Race.Fi: Product topic
Siia postitage oma "Performance & Tuning" uue ja kasutatud kraami Müügikuulutused!!
Re: Race.Fi: Product topic
Weekend offer: Davies Craig water pumps -15%
Lets put the Davies Craig water pumps in -15% discount for this weekend. Eletric water pump ensures that the cooling is sufficient and of course its also possible to replace the old water pump.
With Davies Craig eletric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body which will handle lots of power if needed, for example in race car.
You can get water pumps separately or set, which includes the controller. With controller its possible to adjust water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps we keep always in stock and we order more even twice a week.
Davies Craig water pumps in our webshop:
»» Davies Craig eletric water pumps
Have a great weekend!
-Riku
-Riku
Weekend offer: Widebands -20 €
Let's kick our most popular widebands in our weekly offer -20€. Wideband is a great additon for any tuned engine, which need more fidelity.
Innovate, Vems and PLX now in our weekeend offer -20€ only in this weekend. These three sell high quality widebands for any engine with or without EGT sensor. A wideband is also a very cheap insurance for you engine - it informs any problems before anything bad happens to your engine.
The Vems wideband + EGT is a great and cheaper choice when you also need an EGT sensor especially in turbo engines, of course its possible get the VEMS without the EGT. Innovate is a great choice when you just want a wideband with a traditional and fine look, without any other features than mixtrue ratio - very popular in older engines. The innovate DLG-1 is the dual wideband version which supports two sensors on one gauge and is a very popular wideband in most V6, V8 & V12 engines for example. Last but not least, the PLX is a wideband kit with a modern touch screen and the ability to add extra sensors like boost and egt. We keep all our widebands always in stock.
These widebands in our webshop:
»» Vems widebands
»» PLX DM6 wideband
»» Innovate MTX-L wideband
»» Innovate DLG-1 dual wideband
-Riku
»» Vems widebands
»» PLX DM6 wideband
-Riku
Weekie: Autoglym car care products -10%
Beginning of this week we did add some Autoglym products in our webshop and now they are in -10 % discount in our weekly offer. Autoglym makes high quality car care products for any use.
We added a nice amount of Autoglym car care products in our webshop in this week. Now we have a wide range of Autoglym products in our webshop and stock for any washing need like motor cleaner, interior shampoo, polar blast snow foam and other nice cleaning products.
Polar Blast snow foam for Foam Lance is one of the Autoglyms new products. With Polar Blast prewash is actually a nice job and when it is in the form of foam it can be effected properly and thats how avoid scratching when washing mechanically. Most popular Autoglym products can be found directly from our own stock and of course we order more when needed.
Autoglyms in our webshop:
»» Autoglym car care products
-Riku
This post in our site
-Riku
Weekend offer: Widebands -10%
Let's kick our most popular widebands in our weekend offer -10%. Wideband is a great additon for any tuned engine which need more fidelity.
Innovate, Vems and PLX now in our weekend offer -10% only in this weekend. These three sell high quality widebands for any engine with or without EGT sensor. A wideband is also a very cheap insurance for you engine - it informs any problems before anything bad happens to your engine.
The Vems wideband + EGT is a great and cheaper choice when you also need an EGT sensor especially in turbo engines, of course its possible get the VEMS without the EGT. Innovate is a great choice when you just want a wideband with a traditional and fine look, without any other features than mixtrue ratio - very popular in older engines. We just got a nice amount of Innovate MTX-L in our stock yesterday. Last but not least, the PLX is a wideband kit with a modern touch screen and the ability to add extra sensors like boost and egt. We keep all our widebands always in stock.
Widebands in our webshop:
»» Vems wideband
»» PLX wideband
-Riku
»» Vems wideband
»» PLX wideband
-Riku
Weekie: STRI gauges -15%
Lets kick the high quality and very precise STRI gauges in -15% discount. Most popular STRI gauges are always in our own stock!
STRI makes one of the best gauges in the market for sure! Stri DSD series has a fast and precise servo which will guarantee a precise reading even in harsh conditions. STRI DSD series is very popular in track as it runs perfectly and always shows precise numbers.
STRI gauges are very quiet, almost mute - automatic calibration on every start make sure that you can always get right numbers. Stri gauges are available in different backgroung and led colours or with smoke or clear lens. STRI stock focus turned to the 52mm club sport models with a black dial and clear lens as they are the most popular ones. Other STRI gauges we can get under a week from Europe stock.
Check Stri gauges in our webshop:
»» Race: Stri gauges
-Riku
-Riku
Weekie: Black Diamond -10%
More braking power! Black Diamonds brake parts are excellent update to car which have more power or just for replace old OEM brakes. Now it's possible to get Black Diamond brakes with -10% discount.
Black Diamond has suitable brake parts for any use, even for a race car. Black Diamond brake discs are availabe in three model, grooved, drilled or with both. Brake pads has a good friction and low dust level, they can also handle a big amount of heat. With discs and pads we recommend a braided brake hoses which is a great final update, braking is more accurate when the balloon-like effects leaves from the brake pedal. With discs, pads and hoses the Black Diamond brake fluid is our recommendation so the brakes will run perfectly. We keep the most popular items in stock like brake fluids, best seller pads/discs/hoses.
Check the Black Diamond brakes from our webshop, prices includes -10% discount:
»» Black Diamond brake discs
»» Black Diamond brake pads
»» Black Diamond brake hoses
»» Black Diamond clutch hoses
»» Black Diamond DOT4 brake fluid
-Riku
-Riku
Weekly offer: Sachs SRE clutches -10 %
Proper clutches on offer this week! If the current clutch shows signs of surrender, get a proper one now!
Sachs SRE clutches & clutch parts are on a -10 % offer for the following week. SRE offers great clutches and clutch parts like covers for almost all cars commonly found on the road.
Clutches are available with sintered and organic discs, and our website also lists the torque each cover can handle. If you're after a multiplate kit, ask our sales as those are also available at decent prices and up to 2500nm torque caps!
The catalog, torque spec list and the clutches them selves are here:
»» Sachs SRE clutches
- Willem / Race.Fi
- Willem / Race.Fi
Weekend offer: Eibach springs & suspension kits -10 %
This summer weekends offer are the Eibach springs and suspension kits! Each set ordered on the weekends batch gets an extra -10 % off.
Great suspensions on offer this weekend! Eibach Pro-Kit and Sportline springs, as well as the Bilstein B8-equipped B12 Pro-Kit and B12 Sportline -kits get an extra -10 % off this weekend.
The Pro-Kit range offers mild lowerings from 30 to 25mm. The drop is pretty close to factory oe kits like the BMW M-sport or Audi S-line. Great for looks and driveability without sacrificing too much. The Sportline range offers bigger drops in the 40 to 50 mm range.
Eibach gets consistent good feedback with basically zero bad feedback. We have the B12 kits on our own cars as well - that's how much we like these
You'll find the kits here:
»» Eibach Pro-Kit lowering springs
»» Eibach Sportline lowering springs
»» Eibach B12 Pro-Kit suspension kits
»» Eibach B12 Sportline suspension kits
If you're looking for an adjustable kit, the D2 coilovers are the choice for you. These come with a true coilover design, damping adjustment, separate preload adjustment and camber topmounts on McPherson models. Oh, and they get a ton of good feedback as well
»» D2 coilover suspension kits
Btw; we ship orders over 400 € free of charge to most european countries!
Race.Fi / Willem
Race.Fi / Willem
Weekie: K&N air filters -10%
K&N air filters with million mile warranty! K&N ensures that the engine gets enough air and is one of the most popular upgrades for any car.
K&N makes high quality panel and cone filters mainly for cars but there are filters for motorcycles also - you can get the discount from these as well! K&N air filter are washable and can be re- oiled. Installation is easy - old out, new in. With K&N air filter, the air resistance is much lower, so the engine doesn't need much effort to suck air and that means better fuel economy and higher power.
We have many K&N filters in stock, speacially 3" and 4" cone filters which are the most populare ones and few replacement filters as well. There are also K&N intake kits available, which perform even better thanks to a complete new intake pipeing. Intake kits has places for all original sensors so it does not need any big modifications when installing. We order more K&N air filters weekly and in most cases delivery time is less that one week.
K&N filters in our webshop:
»» Race: K&N air filters
»» Race: K&N cone filters
»» Race: K&N intake kits
»» Race: K&N recharger kit
Have a nice weekend!
-Riku
-Riku
-Riku
-Riku
Weekie: Mishimoto radiators -10%
We just put the Mishimoto radiators in -10% discount in our weekly offer. The Mishimoto cooler increases cooling performance and guarantees perfect operation even in the toughest conditions.
Mishimoto radiators
Mishimoto radiator is a model specific and high quality product which will replace the old original radiator. Mishimoto is more effective than original and excellent choice for any car which needs more cooling power with a great price - no more cooling problems. Mishimoto radiators has a bigger water capacity and engine temperature stays low even in the summer on traffic lights. If there is no suitable model specific radiator available, we have attached a pdf from all Mishimoto radiators. Most popular Mishimoto models we keep in our stock.
»» Race: Mishimoto radiators
Mishimoto coolers
Mishimoto cooler makes sure that the supercharged air is cool enough and the more cooler the air is the more it can be charged to the engine. Mishimoto cooler cools better exchange and flowing intercooler significantly improve the performance of the engine. With Mishimoto cooler the flow resistance is smaller and the turbo or supercharger thong produced by the hot charge air cools more efficiently than the original cooler. You can find the Mishimoto coolers with dimensions so they will fit almost for any car. Most popular ones we keep in stock ready to ship.
»» Race: Mishimoto coolers
Mishimoto fans
Mishimoto electric fan is a compact way to ensure radiator cooling. Mishimoto high-volume fans are both compact and come with an unmatched flow rate. For example there is 8, 10, 12 and 16" models available. Eletrcic fan is also a great choice to use with the original fan to give a additional cooling power. Most popular ones are in stock and yesterday we ordered more fans to fill the Mishimoto shelf.
»» Race: Mishimoto fans
Race.fi / Riku
Mishimoto radiators
Mishimoto coolers
Mishimoto fans
Race.fi / Riku
Weekend offer: STRI gauges -15%
We just put the high quality and very precise STRI gauges in -15% discount. We keep the most popular STRI gauges in stock.
-Riku
-Riku
Weekend offer: RVS products -20%
For the start of this weekend RVS products were put in big discount. RVS is now -20% discount only in this weekend.
RVS is a proven nanotechnology that allows sliding and extremely durable triboceramic surface in parts of engines and transmissions. Engines or transmissions condition improves right away and it is also protected from future wear. The RVS treatment will last 100,000km, so the price does not end up too bad, especially when the prices have now been dropped this much.
RVS treatments can be found for all applications such as engines, transmissions, injection pumps and powersteering. Over the years, RVS has sell a lot and beginning of this week we got more stuff in our shelfs. We keep the most sellest RVS products always in stock.
RVS in our webshop with 20% discount:
»» RVS treatments
-Riku
»» RVS treatments
-Riku
Weekie: Autoglym products -10%
Lets put the Autoglym products -10% discount. Autoglym makes high quality car care products like prewash and Polar blast foam for any use.
We added a nice amount of Autoglym car care products in our webshop a while ago. Now we have a wide range of Autoglym products in our webshop and stock for any washing need like motor cleaner, interior shampoo, polar blast snow foam and other nice cleaning products. Autoglym has products for every step, for example after washing there is a wide range of different waxes available. We also did cleaning packages for interior, wheels, leather etc which contains everything you need.
Polar Blast snow foam for Foam Lance is one of the Autoglyms new products. With Polar Blast prewash is actually a nice job and when it is in the form of foam it can be effected properly and thats how avoid scratching when washing mechanically. To apply the foam, we have foam lance which makes it easy and fast to use. Most popular Autoglym products can be found directly from our own stock and we order more when needed, even every day.
Autoglyms in our webshop at reduced prices:
-Riku
-Riku
Weekie: Kaaz differentials -10%
We have sell lots of Kaaz differentials during this summer and starting autumn as the weather is also looking quite nice. Let's put the Kaaz differentials in -10% discount in our weekly offer.
Kaaz makes high quality differentials for many race/street cars. There is lots of differentials for popular Japan and German car like Nissan and Volkswagen. Kaaz differentials are available with three different ramp angles - 1, 1.5 and 2 way. Kaaz differential is also fully serviceable and you can get all service spareparts quickly from us like friction discs, springs and differential oils.
Kaaz differentials are very popular especially in drifting, rally and time-attack, thats makes Kaaz manly a race differential, but of course it can be used also in street race car which is not a daily driver - it makes a little sound in parking lot but otherwise it works like a charm! Delivery time in Kaaz is usually under a week and for spare parts even a couple of days. Kaaz differentials are also always supplied with the Kaaz oils, which guarantees always the best possible operation in challenging race conditions.
Kaaz differential in our webshop:
»» Race: Kaaz differentials
-Riku
-Riku
