Race.Fi: Product topic
Siia postitage oma "Performance & Tuning" uue ja kasutatud kraami Müügikuulutused!!
Re: Race.Fi: Product topic
Wheel selector is now officially out!
The wheel selector is now officially available from our webshop, which makes it easy to find the correct wheels. Just select the desired diameter, pcd, width and/or offset and it will show all the wheels available with chosen specs.
Wheels selector makes it easy to find the correct wheels as almost 150 wheel articles searched by hand is pretty laborious, especially when you know the specs. Of course its possible to check the wheels like before from articles or brands (its also possible with the wheel selector) - its your choice!
A lot of wheels and accesories (bolts/nuts) have recently been added to the webshop, for example we added all the Rota wheels and Japan Racing wheel amount doubled to the previous one. Spigot rings for the center bore always comes with both wheel brands and with Rota wheels, nuts or bolts are also delivered in the package. After a week of testing, the wheel selector is officially announced, now its time to get some wheels
Wheel selector can be found from here:
»» Race.fi: Wheel selector
Have a great weekend!
-Riku
-Riku
Davies Craig electric water pumps in stock
We just got a nice batch of Davies Craig electric water pumps more in stock. We took more especially 150l/min and 115l/min models.
With Davies Craig electric water pump you can get more power and trust in the cooling system, its possible to use it with the original water pump as a booster or use only the electric pump, either way is fine! There is pumps available between 15-150l/min, smallest ones are with nylon body and biggest models with more durable aluminium body, which is actually a really great thing in bigger flowing rates.
Its possible to buy only the water pump it self or as a set which includes the controller. With controller its you can adjust the water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l and 150l are usually in stock and as said, we got a new batch of these in this morning.
Davies Craig water pumps in our webshop:
»» Davies Craig electric water pumps
Have a great day!
-Riku
Have a great day!
-Riku
Suspension to good shape with a coilover kit
With D2, Eibach and H&R adjustable suspension kit you will get the suspension in shape. We can deliver all the kits fast and most popular models we keep usually in our own stock.
All the three brands has a suitable suspension kit for most common and not so common cars, for example D2 coilover kits has a stiffness adjustment with height adjustment which makes it easy to make the kit perfect for any conditions. Eibach Pro-street S kits are excellent choices especially for street use when you need a height adjustable kit which is also very comfortable.
H&R Twintube and Monotube suspension kits has almost same adjust specs, but Monotube has a different shock absorber type (upside-down) which makes it great also for race use. H&R Twintube is great mainly for street use and Monotube for race use (it also works great in a street car as a compromise).
Adjustable suspension kits in our webshop:
»» Race.fi: D2 coilover kits
»» Race.fi: Eibach coilover kits
»» Race.fi: H&R twintube coilover kits
»» Race.fi: H&R monotube coilover kits
Have a great day!
-Riku
Have a great day!
-Riku
Eibach spacers for coming springs
Eibach spacers makes the car look and feel much better with reasonable price. Widening the track makes the car more stable and it also gives much smoother look. Some of the most popular spacers and bolts/nuts are in our own stock.
Its possible to look spacers by car model or with wheel specs, so basically if you know what car you are driving, then its easy to find the spacers as well. If the car is not known or it is not on the list for some reason, they can also be searched by bolt pattern, width or center bore and of course its possible to ask from us - thats why we are here. Spacers are priced as a pair and most of the thickest spacers comes with new bolts/nuts (depends which ones car uses). Of course it makes sense to buy new bolts/nuts for all new spacers, they are listed separately in our webshop.
Aluminium spacers are also much lighter than steel spacers, but they has the same durability anyway. Some of the spacer models are in our or in our suppliers stock and we always try to keep the delivery times fast as possible - for example we offer express shipping from Eibach, which is usually only a few working days (in finland) to you door / nearest pickup point.
Eibach spacers in our webshopt:
»» Eibach spacers
Eibach bolts, studs and nuts for spacers from here:
»» Eibach studs
»» Eibach bolts
»» Eibach nuts
»» Japan Racing wheel bolts and nuts
Have a great day!
-Riku
»» Eibach spacers
»» Eibach studs
»» Eibach bolts
»» Eibach nuts
Have a great day!
-Riku
Ultralite and XXR wheels in webshop
We have listed all the most popular wheels which are also available in our webshop from both brands. Wheels travels very quickly from the factory and a set of spigot rings are also included for mounting.
The range of Ultralite and XXR covers lots of different type of wheels, for example a 6 and 10-spoke models. There are several color options as well as different bolt patterns, offsets and widths, which you can choose by yourself. Both wheels brands are also supplied with spigot rings, making the installation much easier and safer.
The wheel selector was released last week and it is now running at full power, just choose the correct diameter, width, bolt pattern and/or offset - thats it! Wheels selector also works with XXR and Ultralite brands, so go and find the correct ones
XXR and Ultralite in webshop:
»» Race.fi: XXR wheels
»» Race.fi: Ultralite wheels
Both wheel brands are also in wheel selector:
»» Race.fi: wheel selector
-Riku
-Riku
Bilstein suspension kits and shock absorbers from us
From us, you will find also Bilstein B14/B16 suspension kits and B8 shock absorbers. We have listed few most popular models in our webshop and you can ask suitable kit for your car from our sales.
In this week, we listed few Bilstein B14/B16 adjustable suspension kits and also a couple Bilstein B8 sport shock absorbers. There are only couple of kits available in our webshop, but they are listed mainly to give approx prices and availabilites.
Bilstein B8 shock absorbers are little bit shorter that OEM shocks, so they are excellent for example with Eibach Pro-kit or Sportline lowering springs. Bilstein B14 and B16 kits are adjustable, lowering is between 30-50mm - B16 kits has also a 10 step damping adjustment for compression and rebound (biggest difference to B14 kit). Offer for Bilstein B14/B16 or B8 shocks can be asked from our sales, for example trough spare parts inquiry.
Bilstein suspension kits and shock absorbers in our webshop:
»» Race.fi: Bilstein coilover kits
»» Race.fi: Bilstein shock absorbers
Spare parts inquiry can be found here:
»» Race.fi: Spare parts inquiry
-Riku
-Riku
Model specific suspension listing
Finding the correct suspension parts is now easier than ever! Just select your car's make, series and model, and the shop will show you all the model-specific parts available for it.
The suspension search shows you all the model-specific kits in one view. Whether it's D2 coilovers, Eibach B12 Pro-Kits or B12 sportline suspension kits, or Eibach Pro-kit and Sportine lowering springs, they're all there.
The model-specific listings make things quicker, and you see everything that's model-specific and available at a single glance.
You can also narrow down the lists with the product brand and go deeper to just springs or coilovers. The shop also has several universal parts in the traditional product categories, like adjustable endlinks and coilover helper springs.
Check out the model-specific suspension listings here:
»» Race.fi: Model-specific suspension kit listings
-Riku
-Riku
Correct rims easily through wheel selector
Wheel selector helps a lot to find correct wheels. Just choose diameter, width, pcs and/or offset. In addition, the rims can also be filtered with different wheel brands.
Wheels selector makes it easy to find the correct wheels as almost 150 wheel articles searched by hand is pretty laborious, especially when you know the details. Of course its possible to check the wheels like before from articles or brands.
A lot of wheels and accessories (bolts and nuts) have recently been added to the webshop, for example we added all the Rota wheels and Japan Racing wheel amount doubled to the previous one. Spigot rings for the center bore always comes with all our wheel brands and with Rota wheels, nuts or bolts are also delivered in the package. Usually all the wheels are in european stock, so the delivery time has been under a week in best cases.
Click the banner or this link:
-Riku
-Riku
Super offer: All Eibach products -10%
Lets put Eibach products in -10% discont for the next week. Probably one of the leading spring manufacturers, Eibach is a certain choice for lowering springs, shocks and kits. Eibach also makes high quality wheel spacers and sway bar kits.
Eibach Pro-kit and Sportline lowering springs
Pro-kit and Sportline lowering springs offer superior quality and ride comfort. They are also an OE choice of many factory sports kits from Audi and BMW. Pro-Kits offer drops of around 30mm, and Sportline kits 40 to 50mm.
»» Pro-kit lowering springs
»» Sportline lowering springs
Eibach Pro-kit and Sportline B12 suspension kits
The B12 kits come with Eibach springs and Bilstein B8 dampers which offer firm damping and are designed for lower springs. Most models also have an upside-down design for increased rigidity. Most customers change cars from time to time, and this is a kit many get for their new car as well. That's about as high as customer satisfaction can get
»» Eibach Pro-kit B12 suspension kits
»» Eibach Sportline B12 suspension kits
Eibach Pro-street S coilovers
Eibach Pro-street S coilovers offer a very sporty driveability and a stepless height adjustment, still maintaining a lot of comfort. Offering drops of 20 to 70mm, the Pro-Street S coilovers are a choice of a gentleman seeking the perfect stance.
»» Pro-Street S coilover kits
Eibach Anti-Roll-Kit sway bar kits
A sway bar kit is the overlooked way to increase stability in cornering without sacrificing any of the comfort. Stiffer roll bars keep the car level in corners, and at the same time allow for softer and more comfy springs - or overall better track performance of course - its your choice!
»» Anti-Roll-kit roll bar kits
Eibach Pro-spacers
Eibach Pro-Spacers are an excellent pair to go with Pro-Kit or Sportline lowering springs and when the wheel looks lack "it". Spacers will bring out the wheels by the amount of their thickness from both sides. Spacers can be found with specs (pcd, center bore) or with car model, depends does the listing recognize your vechile.
»» Eibach Pro-spacers
-Riku
Eibach Pro-spacers
-Riku
Eibach Pro-spacers
-Riku
Eibach Pro-spacers
-Riku
Japan Racing wheels can be bought also as "custom"
In addition to the standard range of Japan Racing wheels, many wheel models can also be ordered with the desired bolt pattern and ET number as "custom". In this way, models that have run out of stock, for example, may be ordered little bit faster.
JR is undoubtedly the most popular wheel brand of this spring, they have a terrific look and the quality is at least very good. Delivery is also quite fast, the wheels that are in the factory stock rarely takes more than one week to deliver at least in near of big cities. As said, several Japan Racing models can also be purchased as "custom", the bolt pattern and the ET number can be decided by you (ET is usually set to a certain range where to choose from).
Wheel offset:
Wheel offset is the distance in millimeters from the hub mounting surface to the center line of the wheel. A positive / bigger offset is when the hub mounting surface is toward the front or outwards of the wheel. Negative / smaller offset is when the hub mounting surface is toward the back or brake side of the wheels center line. Offset can also be zero, then the hub mounting surface is even with the center line of the wheel.
Bigger = wheels sit more inwards.
Smaller = wheels come out more.
Wheels includes also model specific hub centric rings and center cups.
Order Japan Racing wheels from here with comprehensive payment methods
»» Race.fi: Japan Racing wheels
Japan Racing bolts and nuts
»» Race.fi: Japan Racing bolts and nuts
-Riku
Wheel offset:
-Riku
Weekie: Eibach spacers -10%
Lets put the Eibach wheel spacers in our weekly offer, with them you will get the perfect look and much better handling. Most popular wheel spacers are usually in our own stock and we can get the fast from the manufactuer anyway, for example with express shipping.
Its possible to look spacers by car model or with wheel specs, so basically if you know what car you are driving, then its easy to find the spacers as well. If the car is not known or it is not on the list for some reason, they can also be searched by bolt pattern, width or center bore and of course its possible to ask our sales for example by email (info(at)race.fi. Spacers are priced as a pair and most of the thickest spacers comes with new bolts/nuts (depends which ones car uses). Of course it makes sense to buy new bolts/nuts for all new spacers (even for thin models). We have listed them separately in webshop with lenght, type and thread.
Aluminium spacers are also much lighter than steel spacers, but they has the same durability anyway or even better. Some of the spacer models are in our or in our suppliers stock and we always try to keep the delivery times fast as possible. Price for the spacers are always for pair, so if you need them front and rear axle, order two sets.
Eibach spacers in our webshop with discount:
»» Eibach spacers
»» Eibach bolts
»» Eibach studs
»» Eibach nuts
-Riku
»» Eibach spacers
»» Eibach bolts
»» Eibach studs
»» Eibach nuts
-Riku
Weekie: Kaaz differentials -5%
Lets put high quality Kaaz differentials on a discount in the form of our weekly offer until next Friday. The Kaaz differential is an excellent upgrade to the track and is also a kind of compromise on the street car.
Kaaz makes high quality differentials for many race and street cars. There is a wide range differentials for most common Japan and European car like Nissan and Volkswagen. For example Kaaz has a differential for VW 02A and 02J transmissions. Differentials are available with three different ramp angle setups, 1, 1.5 and 2 way. Kaaz differentials are fully serviceable and you can get all maintenance parts from us like friction discs, springs and high quality oils.
Kaaz differential is excellent choice especially for drifting, rally and time-attack, thats what makes the Kaaz mainly a race differential, but of course it can be used also in street racer as a compromise. Availability in Kaaz is usually a week, usually even faster. Kaaz differentials are always supplied with the Kaaz own differential oils, which guarantee the best possible operation in all driving conditions in any time.
Kaaz differential in our webshop with discount:
»» Race: Kaaz differentials
Invoice / Part payments:
Collector: 60 days interest-free payment period. 2.95€ invoice billing cost. Available in webshop.
Jousto: 14 days interest-free payment period, 4.90€ billing cost. Available in webshop.
Mash: 14 days payment period, no charges. Available in Race.fi store.
All invoices can be changed to part payment. More information about the payment methods: Race.fi: payment methods
-Riku
-Riku
Now´s the chance to get Eibach products with discounted prices, as mentioned the sale includes all Eibach products from ERS springs to nuts. For a complete suspension upgrade you´ll find the Eibach B12 Pro-kit and Sportline very good, as they include shock absorbers and springs for each corner. Ride stability you will get from (in addition to the suspension) Eibach Pro-spacer wheel spacers and Anti-Roll kits. The most sold products are kept in stock and by ordering you will quickly get even the not-so-popular products.
All Eibach products can be found here:
»» Race.fi: Eibach products
Invoice options at race.fi:
Collector: up to 60 days of intrerest fee free payment time. 2.95€ Invoice fee. Available online.
Jousto: 14 days payment time, 4.90€ invoice fee. Available online.
Mash: atleast 14 days payment time, no fees. Available in store.
All payment types can be changed into part payment. More info about payment types: Race.fi: Payment types
Second tuner meet 20.6.2019
Next month, precisely at 20.6.2019 is being organized this year´s second tuner meet and it starts at 6pm. The plan´s familiar - Coffee, sausages, grill and place are on Race.Fi The event is cost free and for everyone.
Place: Race.fi
Link to the event: Tuner meet 20.6.2019
Have a nice day!
-Riku
Weekie: Davies Craig electric water pumps
Lets put the Davies Craig electric water pumps on discount in our weekly offer. Now its a great opportunity to get more cooling for the hot summer, most popular water pump models are in our own stock and we order more at least every week.
With Davies Craig electric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body which will handle lots of power if needed, for example in race car.
Its possible to buy water pumps separately or as a set which includes the controller. With controller its possible to adjust water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l and 150l are usually in stock and of course we order more when ever needed.
Davies Craig water pumps in our webshop with discount:
»» Davies Craig eletric water pumps
Collector: up to 60 days of intrerest fee free payment time. 2.95€ invoice fee. Available online.
Next month, precisely at 20.6.2019 is being organized this years second tuner meet and it starts at 6pm. The plans familiar - Coffee, sausages, grill and meeting place are on Race.Fi The event is cost free and for everyone.
Place: Race.fi
-Riku
Place: Race.fi
-Riku
