Race.Fi: Product topic
Siia postitage oma "Performance & Tuning" uue ja kasutatud kraami Müügikuulutused!!
Re: Race.Fi: Product topic
Weekie: Amsoil products -10%
From Amsoil oil and additive selections you will find just the product that goes for your car. Let's put the Amsoil -10% discount in our weekly offer. Most common Amsoil products are in stock.
Amsoil is an oil and additive manufacturer founded in 1972 with more than 40 years of experience. There are many different additives and oils for every purpose from a car to a lawn mower. Oils and additives are made from high quality materials and they always guarantee the best performance regardless of the circumstances.
Amsoil additive range covers largely the same type of products as the Red Line, but for example in Amsoil Diesel additive has a useful Cold Flow feature, what Red Line does not have. Cold Flow prevents freezing and the formation of wax crystals what is typical in Diesel engines and lowers friction temperature of up to 15 degrees. The most popular additives and oils will always be found directly from stock.
Amsoil in our webshop:
»» Race: Amsoil oils ja additives
-Riku
This post in our site
-Riku
Weekie: Black Diamond brakes -10%
More braking power with Black Diamond! Brakes are good choice for street or a race car. Most popular brake parts are in stock.
Black Diamond has a great track record both on the streets and competition on both tarmac and dirt. Black Diamond brake discs are available in three model, grooved, drilled or with both.
Brake pads have a great grip and low dust level, they can also handle a big amount of heat. With discs and pads we recommend a braided brake hose kit, which is a great final update. Braided hoses make braking more accurate when the balloon-like effects are reduced from the brake pedal. With discs, pads and hoses the Black Diamond brake fluid is our recommendation so the brakes will run perfectly. We keep the most popular items in stock like brake fluids, best seller pads/discs/hoses.
Check the Black Diamond brakes from our webshop, prices includes -10% discount:
»» Black Diamond brake discs
»» Black Diamond brake pads
»» Black Diamond brake hoses
»» Black Diamond clutch hoses
»» Black Diamond DOT4 brake fluid
Have a great weekend!
-Riku
-Riku
Weekly offer: Sachs SRE -10%
One of the most popular clutches with high torque ratings available for discounted price for a week.
Sachs SRE clutch and clutchparts on discounted price for next week. Application list has clutches with good torque ratings, basically for every car.
Clutches available with sintered or organic discs, and all parts are available separately.
Catalog and products with prices can be found in webshop:
- Sachs SRE clutches
Most popular "Do-it-yourself" pressure plates with good torque ratings, for example 765 and 763 pressure plates can be found here:
- Sachs SRE 763, 765, 707, 645 ja 785 pressure plates
- Race.fi / Ari
- Race.fi / Ari
Weekie: Free oils with all Quaife differentials
For the next week, all Quaife differentials comes with free Red Line differential oils. Quaife is a differential where practicality and comfort fits in same sentence, especially for the changing weather conditions in Finland.
Quaife fits perfectlty and replaces the original differential easily with out problems. In welded models after the welding job you mount the Quaife simply with bolts. Quaife diffs are designed and manufactured in UK, where the professionalism of cars is at very high level. Every single unit is tested before selling that the minimum quality is always the best.
For coming winter, Quaife is great for any weather whether its snowing or raining. We keep the most common diffs always in stock and we order more when needed. Most popular differentials are for mainly for German cars, but we also sell lots of other models for European and Japanese cars. In the coming week, all Quaife differentials are delivered with free differential oils. When ordering the Quaife, it is best to toss the registration number in the order or directly the oil volume and the needed viscosity.
Quaife differentials in webshop:
»» Race.fi: Quaife differentials
-Riku
-Riku
Holset turbochargers in stock
We have sold many Holset turbochargers and we decided to take the most popular model in stock. Other Holset models we can get usually for next day.
Holset has correct turbo for any need, for example HX35, HX40 and HX50 of which Holset HX35 with 12cm2 sells the most. HX35 is a great upgrade for any engine between 1.6-2.0l and gives a great low end torque, very popular in Nissan SR20DET engine.
Almost any turbo its possible to choice water or oil-cooled version, oil-cooled is easy to install but we sell water cooled almost as much. Beginning of this we we took most sellest turbo model in stock and other Holset products can be ordered usually even for next day.
Holset turbochargers in webshop:
»» Race.fi: Holset turbochargers
-Riku
-Riku
Weekie: D2 big brake kits -100 €
Lets put the D2 bid brake kits in fair 100 € discount for a next week. Big brake kits are model specific and bolt-on parts which ensures extremely powerful brakes.
More braking power with D2 big brakes! Big brakes are excellent update for street or race car, it's bolt-on and is delivered with any parts what you need for installation. There is two different types available, Street and Sport, of course with different disc sizes. Biggest difference in Sport and Street is the caliper size which is a slight smaller in Street kits. Street kits comes with dust covers and sport kits without dust covers.
Brake discs are available in 286, 304, 330, 356, 380, 400, 421 and 444mm sizes - so there is a correct one for any use and purpose. For brake pads you can use a D2 own brake pads or Ferodo pads which we can have with very fast delivery and some Ferodo/D2 pads you can find directly from our stock. There also handbrake available for most brake kits wherter its cable or electric one.
Big brake kits in our webshop with discount:
»» Race: D2 Big Brake kits
-Riku
-Riku
Castrol and Red Line price drop
We checked Red Line and Castrol oil and additive pricing, the result was that now the prices are more better than yesterday. Bigger order amounts and better shipping prices show directly in customers price.
Red Line and Castrol prices dropped today, especially stock items are much cheaper in webshop and also in our store. From Castrol, we have took especially motor oils, of course we sell differential and gearbox oils as well, but more less than Red Line. From Red Line we stock and sell mainly only differential/gearbox oils and fuel/engine additives as they sells the most. For example from Red Line we have lots of 75W90NS differential oil and Si-1, 85PLUS and Water Wetter additives. Anyhow, even the Red Line has some items that does not sell that good so we have added them in our outlet list even with -60% discount.
Castrol and Red Line in webshop:
»» Race.fi: Red Line and Castrol
»» Race.fi: Clearance (also Red Line oils)
-Riku
-Riku
Weekie: D2 air suspension kits -100 €
Now is a good time to grab the air suspension kit at a cheaper price. The air suspension kits has gentlemanly driving pleasure and comfort. Air suspension kits can be adjusted directly from the run, kits are completely road legal and model specific.
D2 air suspension is the right choice when elegance, comfort and adjustable height is your thing. You can change the car height while driving and thats very useful when you drive in different conditions. For example its possible to adjust the height lower after a bad road. There is four different D2 air suspension model available: Basic, Deluxe, Gold and Superpro. All the air suspensions are nowdays also very much mot-compatible. Here in Finland you only need wheel alignment report and our D2 approval document.
Air suspension kits has same shocks as in D2 coilovers, shocks has same 36-step stiffness adjustment. Also spare parts are available widely and its possible to buy air bags, compressor and other spare parts separately.
D2 air suspension kits in webshop with discounted prices:
»» Race.fi: D2 air suspension kits
-Riku
-Riku
Winter comes, Triangle winter tires for any weather
Triangle winter tires guarantee a safe grip even in bad weather. The Triangle is 100% designed in Finland, so it's excellent choice especially for our changing winter weathers.
Triangle winter tires with stud or friction design give the best grip and they rock in any weather, rain or shine. Tires has up to 30% higher stud amount, but they do not wear the road surface more than normal winter tires. The studs are mounted with fully automatic machine, guaranteeing excellent grip in curves and straight road.
The Triangle winter tires were added to our webshop few weeks ago and we have sell them nicely in this fall. The best tire is easy to choose from webshop based on diameter, width, profile and tire type (friction / stud). Almost all Triangle tires are available in Finland warehouse and often they are available for us the next business day. We will be able to deliver the tires directly to the customer at no extra cost in Finland if needed.
Triangle tires in our webshop:
»» Race.fi: Triangle winter tires
-Riku
-Riku
Weekend offer: Black Diamond brakes -15%
Lets make a offer for the weekend after a long time! Now we recommend to take advantage of this and get the Black Diamond brakes really cheaply in your shopping cart. The offer applies to all BD products, brake discs, pads, hoses and even brake fluid get -15% off.
Black Diamond has a great track record both on the streets and competition on both tarmac and dirt, they can also be used to replace the OEM brakes. Black Diamond brake discs are available in three model, grooved, drilled or with both. The Brake pads have a great grip and low dust level, they can also handle a big amount of heat. With discs and pads we recommend a braided brake hose kit, which is a great final update. Braided hoses make braking more accurate when the balloon-like effects are reduced from the brake pedal.
We recommend to use Black Diamonds brake fluid with brake parts so the brakes will run perfectly. Discount in Black Diamond is -15% at least, but we have also wide range of outlet BD parts with up to -40% off. Most common discs, pads, hoses and brake fluid can be found directly from our stock. We order more parts twice a week and even the most special discs arrive in less than a week.
Check the Black Diamond brakes from our webshop, prices includes discount (up to -40% off):
-Riku
-Riku
K&N air filters also with dimensions!
Besides model specific panel and cone air filter its possible to look and buy the filters with dimensions. Some of the filters are directly in our stock.
K&N filters with dimensions! There is wide range of cone, panel and even triangle filters which can be found with dimensions from K&N catalog. Usually the filter will fit many other cars as well where it is listed at the moment. From most sellest filter models like 3 and 4" cone filters we keep always in stock as they are also very practical in use. You can look up the filters directly from K&N page or for example email to us and we will check the availability as well.
Clever search engine in K&N website (possible to look with dimensions):
»» K&N filters with dimensions
K&N filters in our webshop:
»» K&N cone and panel filters
Have a great day!
-Riku
Have a great day!
-Riku
Weekie: Widebands -10€
Lets put widebands in 10 € discount for the next week. Innovate, PLX and VEMS widebands can be found on our stock. Of these, there is a suitable widebands for a basic 4 cylinder or even a bigger V8.
There are three major brands in the wideband range - PLX, VEMS, and Innovate, it (Innovate) also has excellent wideband for V-engines, which has been a favorite for American engines when two sensors have two values on the same screen. Innovates basic model MTX-L has also gained popularity over the last few years, even as much as it is now one of the most sold wideband - in the summer, we ordered nice amount MTX-L model in our stock.
If there is wideband in the search for a turbo engine, and it would be nice to keep up to date with the exhaust temperature smartest choise is VEMS. In addition to wideband numbers, the display shows the exhaust temperatures as well which makes it especially efficient for turbo engines. The PLX wideband represents a slightly modern package with a touch screen and it also has been one of the best selling wideband a long time. All widebands are also a cheap insurance for the engine when you see it right away if something is wrong.
Widebands in webshop with discounted prices:
»» Race.fi: Widebands
-Riku
-Riku
Thermo Tec heat shields keeps the heat in right places
Thermo Tec makes high quality heat shielding products almost for any purpose. Fitment is not limited for cars, for example the heat wrap can be used for motorcycle exhaust.
Thermo Tec has a wide range of different type of heat shields available for many use. Heat wrap is easy to install for example in exhaust manifold, it keeps the heat in the right place and also the turbocharger works nicely. Heat shied tubes are very good for brakelines, oil tubes and for example for lambda sensor which is near to the engine. There is also "model specific" heat shields for exhaust, starter, turbo and silencer - they are not car or engine specific, but made for the exact use. We have a big stock of Thermo Tec products, especially 30x30cm heat sticker which can be used almost for any heat shielding.
Thermo Tec products in webshop:
»» Race.fi: Thermo Tec heatwraps
»» Race.fi: Thermo Tec heat shielding tubes
»» Race.fi: Thermo Tec heat shield sticker
»» Race.fi: Thermo Tec heat tape
»» Race.fi: Thermo Tec heatshields
»» Race.fi: Thermo Tec heat blankets
Have a great week!
-Riku
Have a great week!
-Riku
Weekend offer: Davies Craig electric water pumps -15%
Now its a great chance to get electric water pumps with or without controller including -15% discount. Most common water pumps are in our stock.
With Davies Craig eletric water pump you can get more trust in the cooling system, its possible to use it with the original pump or use only the electric pump. There is pumps available between 15-150l/min, smallest ones are with plastic body and biggest models with more durable aluminium body which will handle lots of power if needed, for example in race car.
Its possible to buy water pumps separately or as a set which includes the controller. With controller its possible to adjust water flow and even a fan if needed, for example you can adjust the pump to stay on for a certain time after the engine has been switched off. Most common pumps like 115l, 130l and 150l are usually in stock and of course we order more when ever needed.
Davies Craig water pumps in our webshop with discount:
»» Davies Craig eletric water pumps
-Riku
-Riku
Slippery weathers coming, more grip with Quaife differential
Quaife differential works in every conditions, it is also suitable especially for slippery weather. It does not lock the wheels, but instead transfers more power to the wheel that has more traction.
Quaife is one of the best modifications for a car and especially for Finnish weathers. According to the customer feedback, the most common is the improved grip when comparing to the original diff. Quaife differentials are manufactured and designed in England where the knowledge is in high level and where all the differentials are tested before putting them to sale. Quaife works great even with big amount of snow and with the original traction control, also the yellow light does not flash so often when there is more grip.
We have many differential in stock and we order more every week. Most common Quaifes are for German cars, but there is also a huge range for other car models. Besides differentials, Quaife has a gear kits for transmissions and also a whole transmissions with all parts, ask more from our sales.
More information and Quaife differentials:
Have a great day!
-Riku
Have a great day!
-Riku
