BC Racing ZG-08-BR Coilover Kit, 01-07 P2 Volvo S60 (R)/ V70 (R) AWD
Performance & Tuning parts for Volvo!
Siia postitage oma "Performance & Tuning" uue ja kasutatud kraami Müügikuulutused!!
Gazal
PostitusPostitas Gazal » 19 Nov 2022, 17:27
Müügiks tutikas järelturu komplekt Volvo BR Series Coilover Kit. Jäi üle ja seega ka müügiks, hind on 850€
Kaasa kõik jubinad-pudinad, originaalpakendis :)
Ideaalne neile kel vaja enda Volvo kõrgust muuta, saab auto niivisi paika panna nagu ostja soovib.
NB! Sobib AWD S60, V70, S60R, V70R mudelitele
Poes küsitakse uue komplekti eest 1200€, hea võimalus endale poe hinnast -30% saada
Viide uutele coiloveritele:
https://www.vivaperformance.com/bc-raci ... s60r-v70r/
The BC Racing BR Series offers the most affordable entry into coilover suspension without sacrificing performance, comfort, build quality, vehicle height, or handling. This is done by extensively testing each vehicle then refining the coilover characteristics as many times as needed to ensure the most well-balanced and affordable aftermarket suspension conceivable. BC Racing takes great pride in choosing spring rates for our off-the-shelf kits that strike the perfect balance between comfort and performance so you're never stuck with an oversprung suspension like many other brands sell. BC Racing offers one of the widest ranges of damping adjustment with 30-clicks of compression/rebound adjusted simultaneously on the BR Series. With meticulously chosen spring rates, damper valving, and one of the widest adjustment ranges in the industry, you can't go wrong with the BC Racing BR Series
Coilover System features:
    Highly Customizable
    Mono-Tube Shock Design
    Linear Piston And Damping Curve
    Height Adjustment Independent Of Spring Compression
    30-Clicks Of Simultaneous Compression/Rebound Adjustment
    Front Camber Plates Standard On Applicable Kits
    Rear Camber Plates Available For Applicable Kits
    Custom Spring Rates And Swift Springs Available
    Custom Valving Or Valving Paired For Custom Spring Rates
    1-Year Warranty Against Manufacturers Defect
    Fully Rebuildable
Huvi korral saab kirjutada emaili otse ahti.blumkvist@gmail.com
Viide ka ühele videole, kus pandi S60 külge:
https://www.youtube.com/watch?v=NqT917_C_JA
Võib pakkuda ka vahetust S60R / V70R kraami vastu (pihustid, turbo, pidurid jms).
